Communication with the AeroComm Link (RS232)
Hi guys,
Congrats on the 20 years! I´m new at this and I have a question. I need to connect the propeller with the Aerocomm ConnexLink (RS232). Can I use the circuit shown in the figure in the attachment or do I have to make some type of modification?
Juan Ramirez
Juan Ramirez
(1) By all means leave out the reset-connection!
(2) The 4,7k resistor would function as a "pull-down" to something as -12V so far as it is available on the DTR pin. This is usual but not mandatory. Your voltage swing for sending from the prop wil be -12 <-> +3 V
(3) Either your device will accept 0 <-> 5V, then you do not need -12 V or it will have a standard -12 <-> +12 V voltage, in that case you should protect the transistor basis against the incoming -12 V using a diode e.g..
I know a MAX 233 chip costs around $5 but it will relieve you from any further considerations without any additional part at all.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 9/6/2007 5:21:49 PM GMT
Paul Baker
I need one wireless serial link propeller and AeroComm ConnexLink
Amateur radio callsign: YV3FHR
Paul Baker
Juan Ramirez
http://aliben.wordpress.com/2006/10/24/interfacing-aerocomm-ac4790-with-propeller-chip/
http://aliben.wordpress.com/2006/10/26/testing-the-ac4790-and-propeller-interface-w-alibe-homebase-command-center/
http://aliben.wordpress.com/2006/10/24/aerocomm-ac4790-a-short-introduction/
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
