Communication with the AeroComm Link (RS232) — Parallax Forums
jcrmjcrm Posts: 5
edited 2007-09-07 12:45 in Propeller 1
Hi guys,
Congrats on the 20 years! I´m new at this and I have a question. I need to connect the propeller with the Aerocomm ConnexLink (RS232). Can I use the circuit shown in the figure in the attachment or do I have to make some type of modification?
Juan Ramirez
503 x 349 - 18K
  • deSilvadeSilva Posts: 2,967
    edited 2007-09-06 17:14
    Whatever that device you are talking about ever be, this is not the best possible interface to it.
    (1) By all means leave out the reset-connection!
    (2) The 4,7k resistor would function as a "pull-down" to something as -12V so far as it is available on the DTR pin. This is usual but not mandatory. Your voltage swing for sending from the prop wil be -12 <-> +3 V
    (3) Either your device will accept 0 <-> 5V, then you do not need -12 V or it will have a standard -12 <-> +12 V voltage, in that case you should protect the transistor basis against the incoming -12 V using a diode e.g..
    I know a MAX 233 chip costs around $5 but it will relieve you from any further considerations without any additional part at all.
  • LeonLeon Posts: 7,620
    edited 2007-09-06 17:16
    You might need true RS-232 levels, especially if you don't have the DTR signal available on a PC serial port to give you a negative supply.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 9/6/2007 5:21:49 PM GMT
    edited 2007-09-06 17:23
    Juan what is your intent with the Aerocomm, to provide a wireless serial link, or to program the Propeller?
    Paul Baker
  • jcrmjcrm Posts: 5
    edited 2007-09-06 21:36
    Thanks DeSilva ,Leon and Paul
    I need one wireless serial link propeller and AeroComm ConnexLink
    Amateur radio callsign: YV3FHR
    edited 2007-09-06 21:47
    In that case DTR isn't needed.
    Paul Baker
  • jcrmjcrm Posts: 5
    edited 2007-09-06 22:41
    Thanks again Paul
    Juan Ramirez
  • ALIBEALIBE Posts: 299
    i have been interfacing Propeller w/ Aerocomm AC4790 R/Tx for my robot project.· Purely for communication btwn the robot and the homebase.·
    http://aliben.wordpress.com/2006/10/24/interfacing-aerocomm-ac4790-with-propeller-chip/
    http://aliben.wordpress.com/2006/10/26/testing-the-ac4790-and-propeller-interface-w-alibe-homebase-command-center/
    http://aliben.wordpress.com/2006/10/24/aerocomm-ac4790-a-short-introduction/
    "any small object, accidentally dropped, goes and hides behind a larger object."
    ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
