Spinning logo
Here's my attempt at a Hydra version of the animated GIF from this thread in the Propeller forum, http://forums.parallax.com/showthread.php?p=669987.
Requirements: Hydra, NTSC TV.
A brief video of it in action: www.finitesite.com/mpark/spinning_logo_001.wmv
The conversion to Hydra colors and screen size was done mechanically without a lot of finesse. I think the quality could be much improved if we can just convince Clemens to do yet another version, this time with a Hydra-optimized palette and a funky aspect ratio...
I'd be interested to hear how it looks on other people's TVs. I've only seen it on my little LCD.
The text is a little close to unreadable though. But nevertheless, it is still.
My biggest concern here is that this logo, which is meant I believe just to be a "splash screen" for other programs, by itself takes up almost all of the RAM on the Prop, leaving only 396 free longs for your own code.
While I really don't know much about this, since the image is the same (as far as I know) with the exception of the propeller on the hat itself, couldn't you just animate that, instead of having screen-sized relatively similar bitmaps?
I'm going to use a screen that has a built in SD card for image storage. This will take the load off of the Prop.
As I understand it, I send the LCD controller a command to access the images from the SD card. The LCD controller's built-in ARM microcontroller takes care of displaying it.
Other than that, I agree about the memory issue. I could have cut the propeller frames down even more, but I doubt it would have made that much difference. I never claimed this was useful!
Post Edited (mpark) : 8/31/2007 7:57:26 PM GMT
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/31/2007 7:57:49 PM GMT
Too bad I don't have a Hydra. I tried to "convert" it for the demoboard with the usual adjustments, but somehow it didn't work. Besides I have a PAL TV and none of the HYDRA Drivers seem to have a PAL mode so I couldn't see the colors anyway.
http://forums.parallax.com/showthread.php?p=605385
