Sensorless BLDC motor with back emf? Is there a solution?
ErNa
I do need to drive a brushless dc motor without hall sensors or encoder. Did anyone implement a solution?
There is a slight confusionregarding terminology. A BLDC does have its own electronics and is fed with DC. Other motors, like induction motors, permanent magnet (PM) motors etcetera need something that feeds them with a suitable waveform. Is it one of the latter you are asking about? Or is it really a BLDC you are asking about?
There may be a problem, a PM motor (which it actually is) usually doesn't have much damping. So fast acceleration may be a problem if you do not have a rotor position feed-back. You may need an encoder for that.
Another problem is that the trapezoidal back EMF. It is not an exact fit for the applied sine, so you will have some extra current flowing to compensate for the voltage difference that occurs in the "corners". Adjusting the waveform so it is more like the back EMF helps. And I think that the Propeller is powerful enough to take care of that adjustment automatically. Just feed back the current when running the motor unloaded and let the Prop adjust the voltage profile so that the "parasitic" currents are minimized.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/31/2007 4:34:35 PM GMT
