Parallel interface Character LCD gotchas!
Peter Jakacki
Recently I designed a prop board to interface to a standard parallel interface character lcd module. This is so ho-hum, another lcd module, woo-hoo. But it wasn't so. No matter what I tried the lcd module would not respond
. Tried another from the same batch, same thing. Checked my timing, scoped it out etc and still couldn't get it going. Then I tried a different brand module. Ah ha! now it works! (so it should).
What was the problem? Well that troublesome lcd module had been used in production for years with no problems.
Only difference was that it was run from 5V logic, maybe that was the problem. The easiest way I could test it was to up the supply voltage to the propeller so I connected an infrared led with a voltage drop of around 1.2V (under load) from +5V to VDD bypassing the 3.3V regulator (the prop's absolute max is +4V!!!
). Lo and behold, the beast behaves.
Anyway I've emailed the lcd manufacturer
to find out more about their controller as it's a chip-on-board blob but behaves similar to the standard 44780.
BTW, I use my lcd's in write-only mode by tying the r/w low so that I don't have any voltage interfacing issues plus the operation is deterministic anyway.
*Peter*
. Tried another from the same batch, same thing. Checked my timing, scoped it out etc and still couldn't get it going. Then I tried a different brand module. Ah ha! now it works! (so it should).What was the problem? Well that troublesome lcd module had been used in production for years with no problems.
). Lo and behold, the beast behaves.Anyway I've emailed the lcd manufacturer
to find out more about their controller as it's a chip-on-board blob but behaves similar to the standard 44780.BTW, I use my lcd's in write-only mode by tying the r/w low so that I don't have any voltage interfacing issues plus the operation is deterministic anyway.
*Peter*
*Peter*
Can you illustrate this hack with a quick schematic?
Thanks, Fred
