Parallax Power Supplies - are they universal?
Hello Parallax and forum members,
I was just wondering if the power supplies offered by parallax are universal? (I.e. can take between 100vac ~ 240vac and 50hz ~ 60hz.)· I travel a lot and wanted to know if they would be compatible for my travels.· I know the plug would be a standared US 2 pin socket.
I am interested in the 7.5volt 1amp, and the 12volt 1amp models, personally. :-)
http://www.parallax.com/html_pages/products/componentshop/power.asp
7.5vdc 1amp: http://www.parallax.com/detail.asp?product_id=750-00009
12vdc 1 amp: http://www.parallax.com/detail.asp?product_id=750-00007
Anybody out there know?· It is usually listed on the 'wall wart' what it can take.
failing that - I will probably have to go to digikey or something.· Any recomendations?
Type 1: Hefty Wall Wart
Type 2: Laptop style Power Supply
There's nothing like a new idea and a warm soldering iron.
I would talk to them first, to make sure the model you get can handle it. What's a free phone call worth?
HTH, chris
I'm not scared of your robot. I'm covered by Old Glory (youtube)
I just went back to the stockroom to check this for myself.
Both part numbers 750-00007 and 750-00009 are rated 100-240 VAC 50-60 Hz. I was a bit surprised, because in the past these models of Sceptre power supplies were only 120 VAC input.
Sincerely,
Paul Baker
