data storage problem
Hello everybody,···
I need to store data in memory but I don't want to use my EPROM due a short life and program integrity, help needed,·I want to store 5 readings every 3 seconds any RAM recommended?, thanks.
I would recommend my SD Data Logger if you want to store data on an SD memory card. Then you can put the SD card into a PC and read the data.
http://www.hittconsulting.com/products/sddatalogger/
or the Parallax memory stick logger
http://www.parallax.com/detail.asp?product_id=27937
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
Nuts and Volts 115
- Rick
Ramtron sells a line of what they call FRAM chips that are "drop-in" compatible with standard EEPROMs and don't have the same limitations of write speed and endurance. Have a look at their website.
Chris Savage
Parallax Tech Support
