data storage problem — Parallax Forums
AdrianaAdriana Posts: 7
edited 2007-08-26 18:46 in BASIC Stamp
I need to store data in memory but I don't want to use my EPROM due a short life and program integrity, help needed,·I want to store 5 readings every 3 seconds any RAM recommended?, thanks.tongue.gif
  • D FaustD Faust Posts: 608
    edited 2007-08-23 21:46
    You mean EEPROM, right?· I think EPROM is erased with UV light as opposed to electrically.· Just a clarification.· I think there is a tool that lets you write to memory card, but the name has escaped me.· Check the Parallax site.
    LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
    LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
    ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
    END
  • BeanBean Posts: 8,129
    edited 2007-08-24 00:04
    For how long do you want to store the data ? Minutes ? Hours ? Days ?
    I would recommend my SD Data Logger if you want to store data on an SD memory card. Then you can put the SD card into a PC and read the data.
    http://www.hittconsulting.com/products/sddatalogger/
    or the Parallax memory stick logger
    http://www.parallax.com/detail.asp?product_id=27937
    Bean.
    Teacher: What is the difference between ignorance and apathy ?
    Student: I don't know and I don't care
    Teacher: Correct !
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-08-24 00:08
    It's not clear from what you are asking whether it will do what you need, but you might want to check out how to use a serial eeprom. Here is a Nuts and Volts article that has some info on the I2C version. They are also available in SPI for a bit less code overhead.
    Nuts and Volts 115
    - Rick
    edited 2007-08-24 01:27
    Also keep in mind that you can use an external RTC with battery backup that includes enough RAM for your purposes.
    Ramtron sells a line of what they call FRAM chips that are "drop-in" compatible with standard EEPROMs and don't have the same limitations of write speed and endurance. Have a look at their website.
    I would be inclined to go with the DS1302 or similar and use its RAM. The FRAM chips are all SMD parts as I recall...Not easy to experiment with unless you have a breakout board.
