Passing multiple parameters to a COG running assembly. — Parallax Forums
m.r.b.m.r.b. Posts: 36
edited 2007-08-24 14:50 in Propeller 1
I am still fairly new to SPIN/PROP. chip.... My background is 10+ years PIC (including 18Fxxxx), 5 years before that Z80 CPU & Z80 core MCU's etc...
So... don't shoot me down in flames etc...
Quick question...
I have started a new COG with an assembly program in it, for speed of execution...
(tranlated SPIN I believe·can only change states of pins at best about 29KHz(ish), because its a translated language!!!)
You can·use PAR to pass ONE parameter register for the ASM program....
I have already managed to pass a single LONG to an ASM program, through PAR!!!
I however want to pass more than one 32 bit register to the ASM program....
If·I have multiple·LONG variables·in my parent object, declared sequentially...
IE:-
VAR
·· long x· 'This is the first thing I want to pass to ASM
·· long y· 'This is the second thing I want to pass to ASM
·· long z· 'This is the last thing I want to pass to asm...
·· long OtherThing 'Nothing to do with the ASM program
·· long SomethingElseAgain
In ASM, could I read like this???· (PAR is @x in ASM 'call'....)
·· rdlong fred,PAR
·· rdlong bert,PAR+1
·· rdlong tim,PAR+2
The silly names are just to get the idea across....
Regards M.R.B.
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2007-08-21 12:11
    Lesson three shows this:
    http://forums.parallax.com/showthread.php?p=647408
    your basic idea is correct but the implementation is different
  • AleAle Posts: 2,363
    edited 2007-08-21 12:14
    PAR can contain a pointer to a table of longs, words, bytes whatever you need, and that is passed to asm:
    CNT
    ptr = 0x7ff0
    PUB blabla(..) ..
    long[noparse][[/noparse]ptr] := first_val
    long[noparse][[/noparse]ptr+4] := second_val
    cognew (@init, ptr)
    DAT
    init mov tab_ptr,PAR
    rdlong val0, tab_ptr
    add tab_ptr,#4
    rdlong val1, tab_ptr
    have fun
    edited 2007-08-21 12:35
    They don't have to be a table even, as long as they are defined contiguously they will sit in adjacent memory locations e.g:
    VAR
    long cog
    long pin1
    long pin2
    if you passed @pin1 it would be addressed as PAR and pin2 would be addressed as PAR+4 (because the address is in bytes)
    Graham
  • ericballericball Posts: 774
    edited 2007-08-21 12:46
    1. PAR is a 14 bit value (see PASM COGINIT in the manual for why).· It's meant to pass a long pointer to HUB memory.
    2. don't forget VARs of different sizes will be reordered.
    3. If you're passing static data (i.e. stuff which doesn't get updated after the COG is started), there's no reason you can't set the DAT values directly before calling COGNEW.· (Just be aware COGNEW takes time to execute.)
    VAR
       long x  'This is the first thing I want to pass to ASM
       long y  'This is the second thing I want to pass to ASM
       long z  'This is the last thing I want to pass to asm...
    fredptr := @x
    bertptr := @y
    timptr := @z
    DAT
       rdlong fred,fredptr
       rdlong bert,bertptr
       rdlong tim,timptr
    fredptr LONG 0
    bertptr LONG 0
    timptr  LONG 0
    edited 2007-08-21 13:29
    And further to what Eric said if you know you don't want to change the variables you can actually assign values to the variables used in the assembly code directly before you call coginit and you avoid pointers all together. See lesson one on the same link as above.
    Graham
  • m.r.b.m.r.b. Posts: 36
    edited 2007-08-22 11:20
    Thanks... The ASM lessons, and post examples cover what I wanted to know..
    The pointer method looks the best way, for what I want to do....
    Because ... The values are dynamic (step time delay(s)+step count, for a clock-direction stepper motor driver!!!)
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2007-08-22 21:43
    Another way I have passed an address to assembly is to pass the par, then load an address to the par location from spin, then read the address from assembly.· I have used this where I have multiple cogs that I want to communicate with in assembly.··Remember that the @symbol·translates the address into a number.· Don't try to @ something twice as I have done.·
    edited 2007-08-22 22:00
    A technique I use for pass by value (a value which needs to be communicated to the assembly program but does not change during the execution of the assembly program) is to declare a variable at the end of the assembly routine, then simply assign it's value in Spin before cognew. Like the following:
    PUB go
    · var1 := 126
    · var2 := -1
    · cognew(@asmentry, 0)
    DAT
    asmentry ...
    var1 LONG 0
    var2 LONG 0
    Paul Baker
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-08-22 23:11
    Paul Baker (Parallax) said...
    Paul, is there any particular reason that these values·can not be changed in the assembly program? From inside the assembly they would be just another named register, right?
  • deSilvadeSilva Posts: 2,967
    edited 2007-08-22 23:44
    Erik Friesen said...
    I shall try to explain this: There are four (!) sorts of @ in SPIN
    (1) One is used to find the address-offset of a DAT-Variable as a constant. This is little bit tricky. There is something like a "constant-context" during the SPIN compilation, where all constant expressions are evaluated; this happens most notably in the CON section, but also whenever the directive constant(...) is used, and for all presets or machine language operands in the DAT section.
    Notably for the last application address-offsets are very handy (@datname), it can be added to or subtracted from them, and even differences can be stated (@end-@start or constant(@end-@start)); most other operations are more or less dangerous smile.gif
    Note that these are not addresses, but just some numbers to be offset later! The reason is, that during the evaluation of constants the compiler is not yet in the situation to understand where the addressed variables will be allocated to!
    (2) The second kind of @ is the adress of DAT variables as such (@datname NOT in a constant context); this number is known by the compiler when generating the code.
    (3) The third kind of @ is an address of VAR variables. Why is there a difference? Well you can instantiate more than one object, which will lead to a multiplication of the VAR section, but there will be only ONE code section. Thus the poor code cannot know for which object it will have to work. This has to be computed from case to case dynamically!
    (4) the fourth kind of @ is the address of a "local" variable (or a routine parameter). As SPIN routines can be called recursively this is an address in the stack, different from call to call, but independent of the object instantiation.
    But this was just the preface, now to the question: Why @@ ?
    Well, for the situation (1) - and for this situation only! - this address offset can be converted to a value corresponding to situation (2)
    Example:
    X := constant(@datvar)
    Y := @datvar
    Z := @@X
    Post Edited (deSilva) : 8/22/2007 11:57:53 PM GMT
    edited 2007-08-23 00:05
    Fred Hawkins said...
    Correct, they are variables, but once they are loaded into the cog they become disassociated with the copy in hub memory, so any changes made to thier contents is done in cog only. This is akin to what happens when you change the value of a parameter in a C function,·you change only the local copy, not the origination·variable.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 8/23/2007 8:00:43 PM GMT
    edited 2007-08-23 00:12
    I think Fred was aware of this, as he had read my tutorial smile.gif! He just wondered why he should not be allowed to change it locally in the COG; of course he can.
    edited 2007-08-23 00:58
    It depends from what side you are looking ...
    edited 2007-08-23 03:15
    I am staunchly in the assembly camp. Myopically.
  • mirrormirror Posts: 322
    edited 2007-08-23 04:00
    Myopically? Isn't that Mypokeially?
    Certainly.· One the DAT variables have been copied from HUB to COG, there is no reason the PASM code can't do as it wishes with that "register".· (Personally, I just think of it as 496 words of RAM, with 16 memory mapped registers.)
    The important fact to recognize is once the DAT variable has been copied from HUB to COG, any changes to the HUB version will not be automatically reflected in the COG version.· (And vice-versa.)
