Passing multiple parameters to a COG running assembly.
I am still fairly new to SPIN/PROP. chip.... My background is 10+ years PIC (including 18Fxxxx), 5 years before that Z80 CPU & Z80 core MCU's etc...
So... don't shoot me down in flames etc...
Quick question...
I have started a new COG with an assembly program in it, for speed of execution...
(tranlated SPIN I believe·can only change states of pins at best about 29KHz(ish), because its a translated language!!!)
You can·use PAR to pass ONE parameter register for the ASM program....
I have already managed to pass a single LONG to an ASM program, through PAR!!!
I however want to pass more than one 32 bit register to the ASM program....
If·I have multiple·LONG variables·in my parent object, declared sequentially...
IE:-
VAR
·· long x· 'This is the first thing I want to pass to ASM
·· long y· 'This is the second thing I want to pass to ASM
·· long z· 'This is the last thing I want to pass to asm...
·· long OtherThing 'Nothing to do with the ASM program
·· long SomethingElseAgain
In ASM, could I read like this???· (PAR is @x in ASM 'call'....)
·· rdlong fred,PAR
·· rdlong bert,PAR+1
·· rdlong tim,PAR+2
The silly names are just to get the idea across....
Regards M.R.B.
Quick question...
IE:-
VAR
·· rdlong fred,PAR
·· rdlong tim,PAR+2
Regards M.R.B.
http://forums.parallax.com/showthread.php?p=647408
your basic idea is correct but the implementation is different
CNT
ptr = 0x7ff0
PUB blabla(..) ..
long[noparse][[/noparse]ptr] := first_val
long[noparse][[/noparse]ptr+4] := second_val
cognew (@init, ptr)
DAT
init mov tab_ptr,PAR
rdlong val0, tab_ptr
add tab_ptr,#4
rdlong val1, tab_ptr
that works
have fun
VAR
long cog
long pin1
long pin2
if you passed @pin1 it would be addressed as PAR and pin2 would be addressed as PAR+4 (because the address is in bytes)
Graham
2. don't forget VARs of different sizes will be reordered.
3. If you're passing static data (i.e. stuff which doesn't get updated after the COG is started), there's no reason you can't set the DAT values directly before calling COGNEW.· (Just be aware COGNEW takes time to execute.)
Graham
The pointer method looks the best way, for what I want to do....
Because ... The values are dynamic (step time delay(s)+step count, for a clock-direction stepper motor driver!!!)
PUB go
· var1 := 126
· var2 := -1
· cognew(@asmentry, 0)
DAT
asmentry ...
var1 LONG 0
var2 LONG 0
Paul Baker
(1) One is used to find the address-offset of a DAT-Variable as a constant. This is little bit tricky. There is something like a "constant-context" during the SPIN compilation, where all constant expressions are evaluated; this happens most notably in the CON section, but also whenever the directive constant(...) is used, and for all presets or machine language operands in the DAT section.
Notably for the last application address-offsets are very handy (@datname), it can be added to or subtracted from them, and even differences can be stated (@end-@start or constant(@end-@start)); most other operations are more or less dangerous
Note that these are not addresses, but just some numbers to be offset later! The reason is, that during the evaluation of constants the compiler is not yet in the situation to understand where the addressed variables will be allocated to!
(2) The second kind of @ is the adress of DAT variables as such (@datname NOT in a constant context); this number is known by the compiler when generating the code.
(3) The third kind of @ is an address of VAR variables. Why is there a difference? Well you can instantiate more than one object, which will lead to a multiplication of the VAR section, but there will be only ONE code section. Thus the poor code cannot know for which object it will have to work. This has to be computed from case to case dynamically!
(4) the fourth kind of @ is the address of a "local" variable (or a routine parameter). As SPIN routines can be called recursively this is an address in the stack, different from call to call, but independent of the object instantiation.
But this was just the preface, now to the question: Why @@ ?
Well, for the situation (1) - and for this situation only! - this address offset can be converted to a value corresponding to situation (2)
Example:
X := constant(@datvar)
Y := @datvar
Z := @@X
I am confident you will now understand that X < Y and Y == Z
Post Edited (deSilva) : 8/22/2007 11:57:53 PM GMT
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/23/2007 8:00:43 PM GMT
It depends from what side you are looking ...
The important fact to recognize is once the DAT variable has been copied from HUB to COG, any changes to the HUB version will not be automatically reflected in the COG version.· (And vice-versa.)
