alternative power supply
I am wondering, can I use a power supply from a computer to power the boe instead of a 9volt battery? is there anything that discusses this?
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
A 7.5V to 9V "wall wart" with a current rating of 1-2A is the ideal supply, is pretty cheap, and readily available almost anywhere.
Although you can do much better in terms of variety and price from distributors like Jameco or DigiKey, you can find this at a Radio Shack store:
9VDC 800mA Adapter | Model: 273-1768 | Catalog #: 273-1768
You "could" theoretically connect GND (Black) and 12V (Yellow) from the pc power plug and connect to (GND)<->Vss and (12V)<->Vin as long as something ELSE is plugged in drawing power from the supply. As stated above... the BOE will not make the PC supply behave correctly. Best advice... avoid the temptation of using a PC supply.
There's nothing like a new idea and a warm soldering iron.
Later, I found these instructions tthat detail how to modify a PC supply for use as a bench supply. Works fine for me.
Vern
