Boe-Bot Using Rechargeable Batteries
Hi all,
Sorry if the topic in subject has been discussed before, but for now I still have no time to surf the forum to find it out.
I have new boe-bot rev. C and have ordered parallax adaptor 7.2V, but here I would like to ask about the possibility to use common rechargeable batteries (1.2V with 2500mA, or recently now there is 2700mA, if I am not wrong). I think I would like to make my boe-bot more portable and because in the near future I will make some intensive activities with my boe-bot so I don't want frequently do replacement for (and buy) standard non rechargeable alkaline batteries that boe-bot used.
If it is possible, How many rechargeable batteries should I used in series configuration? (please give me explanation with voltage and current side of view).
Also, I have read about the use of rechargeable Ni-MH battery of 7.2V with 4200mA, but I can't find that type of battery. Is that safe to use this kind of battery? What any other option battery I can used?
Please, give me the information or related links to this topic in this forum.
Thank you very much in advanced.
- Indra.
- Indra.
I use an MH-C777PLUS-II Universal Charger and Analyzer from Maha Energy Corp. to charge the 5 cells without removing them from the Boe-Bot. I made a charging cable with a socket on one end (also from Radio Shack) that matches the power connector from the batteries. The charger comes with a cable with two tinned wires on one end.
If you try to use only 4 rechargable cells, you get only 4.8V which is not enough for the Boe-Boe. You could use a 7.2V R/C car/plane battery pack, but you'd have to figure out how to mount it physically.
Post Edited (Mike Green) : 8/12/2007 4:35:45 PM GMT
As far as searching for this sort of info on the forum, please see this link - http://forums.parallax.com/showthread.php?p=562370·It has some great info.
Whit+
····http://forums.parallax.com/showthread.php?p=655826
Whit+
Senna
