Boe-Bot Using Rechargeable Batteries — Parallax Forums
IndraIndra Posts: 2
edited 2007-08-16 02:33 in Robotics
Hi all,
Sorry if the topic in subject has been discussed before, but for now I still have no time to surf the forum to find it out.
I have new boe-bot rev. C and have ordered parallax adaptor 7.2V, but here I would like to ask about the possibility to use common rechargeable batteries (1.2V with 2500mA, or recently now there is 2700mA, if I am not wrong). I think I would like to make my boe-bot more portable and because in the near future I will make some intensive activities with my boe-bot so I don't want frequently do replacement for (and buy) standard non rechargeable alkaline batteries that boe-bot used.
If it is possible, How many rechargeable batteries should I used in series configuration? (please give me explanation with voltage and current side of view).
Also, I have read about the use of rechargeable Ni-MH battery of 7.2V with 4200mA, but I can't find that type of battery. Is that safe to use this kind of battery? What any other option battery I can used?
Please, give me the information or related links to this topic in this forum.
Thank you very much in advanced.
- Indra.
    edited 2007-08-12 16:29
    You should use 5 x 1.2V rechargable batteries in series to provide about 6.2V for the Boe-Bot. You can put 4 of these cells in the standard Boe-Bot battery holder, then mount an additional 1 AA cell holder (from Radio Shack) on the metal platform above the ball/wheel. I used glue to hold this in place, then wired the extra cell in series with the original battery holder.
    I use an MH-C777PLUS-II Universal Charger and Analyzer from Maha Energy Corp. to charge the 5 cells without removing them from the Boe-Bot. I made a charging cable with a socket on one end (also from Radio Shack) that matches the power connector from the batteries. The charger comes with a cable with two tinned wires on one end.
    If you try to use only 4 rechargable cells, you get only 4.8V which is not enough for the Boe-Boe. You could use a 7.2V R/C car/plane battery pack, but you'd have to figure out how to mount it physically.
    Post Edited (Mike Green) : 8/12/2007 4:35:45 PM GMT
  • WhitWhit Posts: 4,191
    edited 2007-08-12 17:40
    As he always does, Mike has given an excellent answer to your question.
    As far as searching for this sort of info on the forum, please see this link - http://forums.parallax.com/showthread.php?p=562370·It has some great info.
    Whit+
  • WozooWozoo Posts: 14
    edited 2007-08-12 18:07
    I have found that both my BoeBot & Homework board work fine as long as I use alkaline rechargeable batteries. They are able to hold 9 volts when recharged. Although they are more expensive initially, recharging sure cuts down on the numbers of batteries you have to buy!
    edited 2007-08-12 18:10
    About the rechargeable alkaline batteries - I guess I should be a bit more definite - I am using 4 1.5 volt rechargeables for my BoeBot and a 9 volt rechargeable for the Homework board, which I am presently endeavouring to turn into a robot, too.
    edited 2007-08-12 19:11
    There's a solution forthcoming from Parallax: the BOE-Boost, which adds an extra cell (or two) to the four-battery holder. You can read about it here:
    ····http://forums.parallax.com/showthread.php?p=655826
    edited 2007-08-13 02:26
    Thanks for the link Phil. That is a neat little product. Wonder when we might see those?
    Whit+
    edited 2007-08-13 03:48
    'No idea. 'Still waiting for first articles...
  • SennaSenna Posts: 6
    Hi, guys I'm using 6 1.2 volts Nimh bateries for my boe without any issues. I have made a clip that connects to botton where the original battey holder was located. Couple things: I would not recommend to use 1.5 V batteries with this setup for all the reasons that have been indicated. The space is very tight but is possible take a look @ my pics.
    Senna
    2304 x 1728 - 726K
    2304 x 1728 - 701K
