please test my online PROP
Hi freaks,
could you please have a look at this internet enabled PROP (easyPROP with ENC28J60):
http://213.84.77.105
Its just for testing
thanks
Franz
thanks
Franz
Coley
Any chance you'll publish a schematic we can put in the Cookbook?
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
I got the counter at 0001 ! (does it count ?)
Post Edited (Ale) : 8/15/2007 5:09:26 PM GMT
the counter is not counting :-(
Will have a look tomorrow or later on
but the important thing is that my hardware is running stabil and not burning away.
It draws now 190mA and is powered via USB.
I make a 24hr onlinetest with this setup.
Franz
Well done.
(No I'm not going to do that to you.. [noparse]:)[/noparse]
Oldbitcollector
My main computer is a iMac, but for PIC or Prop work I'm using a IBM ThinkPad PC.
Using the iMac, nothing shows except some text at left/top, no scrolling available, no graphics (that I've seen from forum image).
Using the ThinkPad, that URL won't even begin to load anything from the browser.
Several years ago when I tried to bring up a web site I noted the differences that different browsers don't seem to do things the same or correctly. Apparently these browsers weren't developed from the same specifications.
Just a note from another user.
Harley Shanko
h.a.s. designn
its "tricky" done and its counting :-)
Franz
Gr,
Xander
| Any sufficiently advanced technology is indistinguishable from magic.
Looks great, Hits were 168,169.
Rob7
Im using Firefox if it makes any difference.
I was hit # 233
Nice work [noparse]:)[/noparse]
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Gr,
Mightor
I totally agree with mcstar!!!!
Works for me from Holland on Firefox 2.0.0.6!
Good work gentlemen!!!
-Parsko
It's working right !
I'm ok with Graham and impatient to see the complete project description !
Well done Franz !
dro.
in medio virtus
for testing my new hardware i use the Harrison propTCP.
The ENC28J60 is connected to P12,P13,P14,P15 and P17.
Here are some hardware details:
but all ok with :
Opera
Version
9.20
Build
8771
Platform
Win32
System
Windows XP
Java
Sun Java Runtime Environment version 1.6
up to 657
Great!! work.
many thanks for the testings
The Harrison propTCP works great and you guys can not "kill" the running application.
The hardware works great, nothing burned down, yet.
Its just great.
thanks
Franz
Congratulations !! good job !! it worked for me too.
Will you post some code for the prop ethernet ??
Do you have a assembled version of your board, with ethernet included now ?
Regards.
Alberto.
Regards.
Alberto.
There are some·Boards ready, inclusive the ENC28J60 and the MagJack.
best regards
Franz
(klick the Propeller I/O Control link).
have fun
Franz
Brian
uController.com - home of SpinStudio
