Using Propeller Proto Board with USBto232 Adapter
william chan
Hi Green,
I think I can use part #28030 USB to 232 Adapter with the Propeller Proto Board, but I am not sure of the pin connections.
Can you help me out?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
I wanted to use USB2SER to connect to the ProtoBoard but I realised that it was using the outdated FTDI232BM chip.
That is why I want to try to use #28030 which uses the newer FTDI232RL chip.
I think I need to make a short cable that connects the 9pin "D" connector on the #28030 to the Header Pins (meant for PropPlug) on the Protoboard.
I hope you can give me the pin connections for this short cable.
www.fd.com.my
www.mercedes.com.my
If your using this Parallax item:
http://www.parallax.com/detail.asp?product_id=28030
You will need to build this circuit:
http://www.parallax.com/dl/docs/prod/prop/SerialtoPropeller.pdf
Since Item#: 28030 connects USB from the PC and converts it to serial (RS-232)
However if you have this Parallax item: (USB2SER) (USB to Serial TTL)
http://www.parallax.com/detail.asp?product_id=28024
Then you'll have to move or add a four pin header to the Propeller ProtoBoard:
http://www.parallax.com/dl/docs/prod/prop/Propeller-ProtoBoard-v1.1.pdf
Hope this helps,
Post Edited (Mike Cook) : 8/15/2007 1:33:30 AM GMT
There is the three transistor circuit on page 5 of the Propeller Datasheet:
http://www.parallax.com/sites/default/files/downloads/P8X32A-Propeller-Datasheet-v1.4.0_0.pdf
