Crystalfonts 4 x 16 help
TC
Hello all,
I just bought a display from Crystalfonts. But I am having trouble gitting it to work. I am using "Improve LCD Demo" from Steve Almond. I changed LINELENGHT from 20 to 16. when the demo runs I get jerbish on the display, also only lines 1 & 3 are lit. as the demo starts up you can see all 4 lines activate, but then 1 & 3 are on. I am still learning to program in SPIN so please be easy on me. I have included the datasheat for my display.
thanks
TC
We all make mistakes when we are young………That’s why paste is edible!
thanks
TC
Change that in your driver...
TC
This is an excellent idea!
But I also post a driver by Marcel Majoor, which I configured for a four line display in nibble mode. Works fine!
Edit:
I think I also changed the control pins
The original driver had 8,9, and 10, which is more logical... but you can of course use whatever pins you like
Post Edited (deSilva) : 8/8/2007 3:30:19 PM GMT
TC
Post Edited (TC) : 8/8/2007 11:59:25 PM GMT
thanks
TC
Try doubling the "Delay" in line 270.
This driver - and most others -do not check the "busy" condition, to avoid reading from the display
TC
TC
Whatever, add ",0" after your string. This is what the string(.....) constructions does automatically.
This is a very good explanation for the look of the screen shot you provided: The driver tried to copy A LOT of memory to the display
I also add the test program from Marcel for safety.
Post Edited (deSilva) : 8/10/2007 3:56:46 AM GMT
It is working. Thank you deSilva for all your help. now I have a reason to learn spin
TC
