Linux and prop?
Is there any way to run the prop tool in linux. I attemped using wine and the program sucessfully started but then when I tested the hardware connection a text box appeared and said that no serial ports were detected.
p.s.
I am using ubuntu linux.
p.s.
Thanks for the response
There are all kinds of useful threads linked from the "sticky threads" at the top of the Propeller Forum thread list.
Whenever anyone mentions that something has been posted here before ... look on those "sticky threads".
The compiler allows you to save the binary output from the Info window after a compile.
Having said that, I will continue to beat on WINE as time permits to get the software running properly.
Propterminal ran ok under WINE using the same serial connections, so I know WINE can access the ports correctly.
