Hyperterm alternatives for on Vista
Due to there not being a "debug" window in Prop Tool, the Prop tutorials refers its users to an application called Hyperterm. This application, however, is no longer shipped with Vista. It was a 3rd party application in any case and prior to Vista it was shipped merely for convenience. We all know that convenience is something that must be stamped out and dealt with harshly. So in order for budding Propellerites to still be able to debug their favourite new controller here are two good alternatives:
PuTTY - It can do serial but it's also a telnet, ssh and rlogin client. It has only one drawback; you can't momentarily disconnect without exiting the application. I use it together with a nice Gadget on my sidebar that allows me to single click on the various configurations to start it on COM5 with the correct baud rate. The gadget is called PuTTYpal, you can find it on the gadget site (right click on your side bar->add gadgets->get more gadgets online) You can download PuTTY itself here: http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html.
HyperTerminal Private Edition - Available from http://www.hilgraeve.com/htpe/. I have only ever used PuTTY, so I can't tell you if HyperTerminal PE is any good, but I think it allows you to at least temporarily disconnect from the COM port while you reprogram the Prop.
There you have it. I am sure there are almost as many alternatives to these two free programs as there are members on this forum.
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
Gr,
Mightor
The don't make a VISTA version (symantec product) and probably won't, but I'm sure it'll still work (just might not have ALL the bells and whistles).
I can change baud rates and stop bits on the fly as well as com ports! Very good, will do logging and supports modems as well!
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
* Find your XP Pro/Home CD
* Instert it into your CD ROM drive
* Reboot the computer with the CD enabled as a boot device
* Install XP by fist deleting the partition with Vista on, and then creating a new partition for XP.
This solves all kinds of problems, and seems to signficantly increase performance of the machine.
John R.
Click here to see my Nomad Build Log
I think you misread the thread's title. This one is about alternatives for Hyperterm, not Vista.
Mightor
John R.
Gr,
Mightor
| Any sufficiently advanced technology is indistinguishable from magic.
TerraTerm:· http://hp.vector.co.jp/authors/VA002416/teraterm.html
[url=mailto:Br@y's]Br@y's[/url] Terminal: http://www.smileymicros.com/download/term20040714.zip
There's nothing like a new idea and a warm soldering iron.
Hyperterminal
- Rick
