Hyperterm alternatives for on Vista — Parallax Forums
MightorMightor Posts: 338
edited 2007-08-11 13:20 in General Discussion
Due to there not being a "debug" window in Prop Tool, the Prop tutorials refers its users to an application called Hyperterm. This application, however, is no longer shipped with Vista. It was a 3rd party application in any case and prior to Vista it was shipped merely for convenience. We all know that convenience is something that must be stamped out and dealt with harshly. So in order for budding Propellerites to still be able to debug their favourite new controller here are two good alternatives:
PuTTY - It can do serial but it's also a telnet, ssh and rlogin client. It has only one drawback; you can't momentarily disconnect without exiting the application. I use it together with a nice Gadget on my sidebar that allows me to single click on the various configurations to start it on COM5 with the correct baud rate. The gadget is called PuTTYpal, you can find it on the gadget site (right click on your side bar->add gadgets->get more gadgets online) You can download PuTTY itself here: http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html.
HyperTerminal Private Edition - Available from http://www.hilgraeve.com/htpe/. I have only ever used PuTTY, so I can't tell you if HyperTerminal PE is any good, but I think it allows you to at least temporarily disconnect from the COM port while you reprogram the Prop.
There you have it. I am sure there are almost as many alternatives to these two free programs as there are members on this forum.
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
  • steve_bsteve_b Posts: 1,563
    edited 2007-08-07 18:06
    Procomm Plus is what I use.
    The don't make a VISTA version (symantec product) and probably won't, but I'm sure it'll still work (just might not have ALL the bells and whistles).
    I can change baud rates and stop bits on the fly as well as com ports! Very good, will do logging and supports modems as well!
    <FONT>Steve
    What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
    Lee Travino after the second time being hit by lightning!
  • John R.John R. Posts: 1,376
    edited 2007-08-07 18:50
    I've found a more viable alternative is to do the following:
    * Find your XP Pro/Home CD
    * Instert it into your CD ROM drive
    * Reboot the computer with the CD enabled as a boot device
    * Install XP by fist deleting the partition with Vista on, and then creating a new partition for XP.
    This solves all kinds of problems, and seems to signficantly increase performance of the machine.
    John R.
    Click here to see my Nomad Build Log
  • MightorMightor Posts: 338
    edited 2007-08-07 18:55
    John R,
    I think you misread the thread's title. This one is about alternatives for Hyperterm, not Vista.
    Mightor
    edited 2007-08-07 21:01
    No, I read the title, was just offering another "tounge in cheek" alternative for the fact that Hyperterm is missing from Vista·smile.gif
    John R.
  • inakiinaki Posts: 262
    edited 2007-08-10 18:40
    Actually the Hypertem.exe/dll that comes with XP works under Vista too. You can copy it from an older XP version over your Vista installation. Note that you need to copy two modules: hypertrm.exe and hypertrm.dll.
    edited 2007-08-10 18:46
    inaki said...
    I am not sure if that poses a license problem, though. HyperTerm as shipped with pre-Vista Windows might only be legally usable with those versions. I Am Not A Lawyer, though.
    Gr,
    Mightor
    | Any sufficiently advanced technology is indistinguishable from magic.
    edited 2007-08-11 00:46
    STGold / SimpleTerm from www.ptronix.com [noparse][[/noparse]It's try it before you buy it s/w.]
  • pwillardpwillard Posts: 321
    edited 2007-08-11 05:44
    More·free ones to try, though not designed for vista:
    TerraTerm:· http://hp.vector.co.jp/authors/VA002416/teraterm.html
    [url=mailto:Br@y's]Br@y's[/url] Terminal: http://www.smileymicros.com/download/term20040714.zip
    There's nothing like a new idea and a warm soldering iron.
  • RDL2004RDL2004 Posts: 2,554
    HyperTerminal Private Edition is free and can be downloaded from Hilgraeve:
    Hyperterminal
    - Rick
