SOLVED: Reasons why prop IDE won't install?
Oldbitcollector (Jeff)
I'm re-installing the Propeller tool (latest version) on my system.
I had an install that corrupted, so I've remove it, but for some reason when I run the install, it extracts the msi,
but stops without running it.
Can someone give me a clue as what is happening.
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Post Edited (Oldbitcollector) : 8/4/2007 10:03:52 PM GMT
Oldbitcollector
Basic problem with C:\windows\system32\msiexec.exe (0 bytes)
Replaced file, problem solved! Can't wait until Chip releases a prop that doesn't require a windoze IDE!
Oldbitcollector
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
