Pin broke off PWMPAL
Yesterday I was attempting to get my new pwmpal working so I inserted it and the stamp onto my boe-bot as the directions say.· I was unable to get a good connection to·the stamp so I inserted the pwmpal into the boe's breadboard.· When·I went to remove it, it didn't come out straight and as a result pin 15 was severely bent.· I tried to bend it back but it snapped off.(only the·thin metal piece not·the whole pin on the underside)·
What should I do?
I was thinking that I should take one of the jumper wires from the bot kit and solder it to where the pin broke off (obviously I would cut the excess off).· The only problem with this is that am not so great at soldering, and think that I might mess it up.· Are there any other ways?·
If I have to purchase another one (because I can't fix the one I have) I think that I would rather buy an SX chip and SX blitz, because I could use them for other purposes later.·1) Is there anothing else that I·would need? 2) Does anybody have code similar (or identical) to that of the pwmpal or is that guarded?(I have not used an SX before, but I wouild like to head that·way)·
Note:·I know that the pwmpal saves space but it also eats up 8 I/O pins, so (as I tried) I would rather mount it apart from the stamp (I know the connections from a previous post.)
I greatly·thank anybody who can help me, and am sorry for the lengthy post, but I want to get my whole story out.
P.S. Was something wrong yesterday around this time because I wasn't able to post then?
D Faust
What should I do?
D Faust
Craig
My Blog: Prog | Electro | Mech
I would love to change the world, but they won't give me the source code
People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows.
I spent a minute looking at my own code by accident. I was thinking "What the heck is this guy doing?"
D Faust
As good as new.
John
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 8/5/2007 2:25:10 AM GMT
John, I like your idea.· Because it is pin 15 it should be easibly reachable from the side to solder.· One question- are the pin on the bottom·usually .1 in apart as on the top,·so it could be placed in a breadboard or where it is supposed to go?
D Faust
Chris Savage
Parallax Tech Support
D Faust
