latest prop vid :) — Parallax Forums
latest prop vid :)
BaggersBaggers Posts: 3,019
edited 2007-08-04 10:17 in Propeller 1
Over in prop forum, don't know if you guys use the prop forums too.
http://forums.parallax.com/showthread.php?p=665397
So yes, the prop can do 16bit graphics, I've got a vid to prove it.
It's also a scan line renderer display, so I'm gonna do a tiled background for it next stage [noparse]:)[/noparse]
Post Edited (Baggers) : 8/3/2007 4:25:49 PM GMT
    edited 2007-08-03 19:24
    This is really cool. Nicely done.
    What does the video output circuit look like?
  • BaggersBaggers Posts: 3,019
    edited 2007-08-03 21:24
    Hi Potatohead,
    It's pretty simple, just 3 x 5bit r2r ladders for R,G,B and 1k res for VHsync.
  • CardboardGuruCardboardGuru Posts: 443
    edited 2007-08-03 22:41
    So are you outputting the video on 16 output pins, with a cog changing the pins states by timing with code? Or do you use the counters somehow?
    Help to build the Propeller wiki - propeller.wikispaces.com
    edited 2007-08-04 07:33
    CardboardGuru, yeah, I'm outputting the video on 16 output pins, with a single cog, changing the pin states by timing for the V & H Sync's, but not for the pixels, that's pure asm timing.
    edited 2007-08-04 10:14
    OK, yeah that makes sense. Great job.
    So are you driving the TV in RGB monitor mode, or do you have some circuit to convert to NTSC/PAL?
    I'm driving the TV in RGB monitor mode, but I'm thinking of getting a AD723/4/5 to convert it to composite, so others can see it.
    It's just PAL at the mo. I will however get round to doing an NTSC version too.
