latest prop vid :)
Over in prop forum, don't know if you guys use the prop forums too.
http://forums.parallax.com/showthread.php?p=665397
So yes, the prop can do 16bit graphics, I've got a vid to prove it.
It's also a scan line renderer display, so I'm gonna do a tiled background for it next stage [noparse]:)[/noparse]
Post Edited (Baggers) : 8/3/2007 4:25:49 PM GMT
What does the video output circuit look like?
It's pretty simple, just 3 x 5bit r2r ladders for R,G,B and 1k res for VHsync.
Help to build the Propeller wiki - propeller.wikispaces.com
So are you driving the TV in RGB monitor mode, or do you have some circuit to convert to NTSC/PAL?
It's just PAL at the mo. I will however get round to doing an NTSC version too.
