Need someone to build a LED array controller and probably a computer programmin
I am new here and not sure if I posted in the right forum.
As title suggest, I need someone to build a controller for a LED array.
The LEDs will mostly in·two colors and probably·a little of·a third color.
I am thinking of using power LEDs upto 5W each·in strips·.· Total·power of the LEDs·will be ~150W.·
Dimmable, groups of individual color LEDs controllable, timer for groups of the LEDs.· Some kind of EEPROM or such to remember presets which should be reprogrammable with software. ·A simple computer interface for easier re-programming presets.
I think a combination of micro-controller,·a bunch of relays·and some constant current drivers·is the way to go, am I right?· Please elaborate here·or email me if you want to make me one at Wingoagency@yahoo.com.· Of course, I will pay for it.· I have some knowledge in electronics and computer programming knowledge would enjoy going to to program the micro controller again.· The ones I did was·old timer and not as sophisticated the nowadays "robot chips"
Thanks in advance.
Thanks in advance.
Chris Savage
Parallax Tech Support
I hope to sell the 4 channel PWM controller for $49.00 in a few weeks. 6 AMPS per channel. Or you can use the PWM output to drive your own fets or triacs is you wish to use higher voltage.
Let me know some more details on how you want to interface with it.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
I will be posting the more exact design requirement and do my research early starting next week.
Hopefully your stuff can help me finish my project.··
Can you make PWM controller with more channels ?· I also use DMX512 controller for my stage lighting.· I have four moving heads, strobe light, a DMX controllable power outlet and thinking of adding controllable LEDs for my the DJ booth.· LMK the features of your controller like may be pic of it.· I have friend who use a musical keyboard as a controller and the cutest one I have seen is a gameboy as a controller.
BTW, do you know where to DL the free FreeStyler?.· I only get to the forums but cannot find the DL page.
Hope this helps. I'd never seen any software like this - pretty neat!
Whit+
May I ask what micro you're using for your DMX projects?
I am going to keep the software and connections private though.
I just finished taking apart an americanDJ mini spot ($129.00) it actually uses an old Atmel at89C chip so they are doing the PWM with software as it has no PWM hardware on the chip.
Here are some pictures of some of the tests I am running using the LuxeonIII's
http://www.acousticlights.com/gels.html
http://www.acousticlights.com/compare.html
Post Edited (WingoAgency) : 8/3/2007 3:26:12 AM GMT
Would it be .03192 US cents * 280LM = $8.93 US dollars? I would say how much is shipping! My price is $22.75. I don't even see any 10 watt prices.
This Rebel is even brighter than the luxeonV. I have some of these on order, my price is $11.99 The Dominant Wavelength is 6500K
7007-PWC-09-1 Luxeon Rebel Star - White, 160 Lumens @ 700mA
Oh I found a quad driver I plan to use, Digikey# 497-2700-5-ND The specs are amazing on this part. It's a high side part as well. ST Micro makes the best drivers I think. Hey I just typed in ST on the part search on eaglecad and what do you know they have the part in the library, very cool, now I don't have to make it.
As for getting the Luxeons, what's the quantity the discount starting at?· Do you want to do a group buy.· I can use about 200W of LEDs mix and match.· But I only need white(80,000K plus)·and blue 420-476 nm are all fine.
Post Edited (WingoAgency) : 8/3/2007 2:58:19 PM GMT
Not really much discount on qty till your over 10,000 pcs. I use aluminum to heat sink.
Chris I.
http://www.freewebs.com/artdecojukebox/lightgridvideos.htm
http://www.freewebs.com/artdecojukebox/lighjtgridsoftware.htm
Kevin
Here are some more stuff I have defined for the projects.
I have picked some Power LEDs so that all of us can debate the benefits or disadvantages of them. However, I don't know how to post files (they are in PDF and Word format) in this forum? Can some give me some pointers-I canno open my attached pdf.
Basically, I have decided to go wtih
5W White LED, 60000-8000K, 6-7.5V 200-280LM
1W Blue LED, 460nm, 3.5(typical)-4(Max)V, 10-15LM or
10W Blue LED, 465nm, 30(typical)-33(Max)V, 90LM
Some of my concerns in choosing the two different LEDs are the number of pcs I have to solder and the eveness of the light. The projecting distance from the light sourse are around 18-36 inches. That is, if I go with 10W, I solder only 8 pcs while if I go with 1W I have to solder ~60 pcs for the same amount of LM. However, the ~60 pcs can be more evenly spread out along the fixture and thus give me much even light close to the "bulb" The cost is similar in either 1W or 10W LEDs for the same amount of LM. Next concern is the voltage: the 10W ones uses 30-33V which is way above power supplies I can find handily. I am think of using old PC power suplies because they have 12V lines and that I hav emany old computer PS everywhere in my house. BTW what can I use to load the PC PS-a sandbar or what spec?
thanks for any input, I am such a newbie in this thing
Post Edited (WingoAgency) : 9/14/2007 5:52:24 PM GMT
How are you going to heatsink those 10W LEDs?
Chris I.
Post Edited (WingoAgency) : 9/16/2007 7:08:33 AM GMT
I am using power LEDs so look like a star. I am thinking of using some screws but have to insulate it so that it won't touch the conacts on the surface of the bulbs. At the same time, I have to have them tight on the surface of the aluminium sheet so that heat can be tranfserred properly.
Any inputs?
As for the heat sink I got a big heat sink. It may be a poser but at least it looks good. Hehe
http://www.anandtech.com/casecooling/showdoc.aspx?i=2978&p=2
Now back to the very first question I am asking for one of you guys to program a controller for me so that I can controll this fixture with computer. I will write my own user interface with high level language package MS Visual Baisc and send a matrix of of information to turn on and off each bulb at a certain time. I need someone to program the controller so that it receive information from my computer may be thru a USB port of such. In the old days I have done a parallel port controller to turn on and off 8 lights using relays so I guess you guys can come up with something for LEDs with micro controller as well. I will pay for your trouble of building, programming and such and please offer me a deal.
Thanks in advance.
The LEDs are mostly 10V 10W ones and most likely I want each one to be individually programmable unless financially prohibitive. So far I am thinking of 10 pcs of 10V 10W White LED and 4 pcs of 10V 10W Blue LED and 2 pcs of RED 1 W LED.
Update after·6 hours operation.
With just an alluminium frame the temperature of the LEDs will stable at 110F and the glue looks like holding alright.· There seems to have no visual degrading of the light intensity either.· Nevertheless, I will put a fan to see how much coolr it will get to.
Post Edited (WingoAgency) : 9/28/2007 3:22:02 AM GMT
I sent you a PM
