toggle I/O pin
Hi,
I am trying to toggle an I/O pin of Basic stamp SX controller at 5MHz using High - Pause - Low commands but I can only reach few hundred Kilo Hertz.
Can anyone tell me if I can toggle an I/O pin at 5MHz and if so what command do I have to use?
If you are using the SX28 or SX48, if you use a fast 50MHz clock you should be able to toggle that fast.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
