toggle I/O pin — Parallax Forums
toggle I/O pin
khannad1khannad1 Posts: 2
edited 2007-07-27 01:17 in General Discussion
I am trying to toggle an I/O pin of Basic stamp SX controller at 5MHz using High - Pause - Low commands but I can only reach few hundred Kilo Hertz.
Can anyone tell me if I can toggle an I/O pin at 5MHz and if so what command do I have to use?
  • BeanBean Posts: 8,129
    edited 2007-07-27 00:41
    If you are using the BS2SX then you cannot toggle at 5Mhz.
    If you are using the SX28 or SX48, if you use a fast 50MHz clock you should be able to toggle that fast.
    Bean.
    Teacher: What is the difference between ignorance and apathy ?
    Student: I don't know and I don't care
    Teacher: Correct !
    www.hittconsulting.com
  • khannad1khannad1 Posts: 2
    Bean, Thank you for the information
