Mobile Prop Demo Board (in 3d?)
In the photo you can see a USB powered Propeller demo board connected to USB powered 3D visor·via VGA connector.· So, I can work (play) with Spin code when I go to Europe soon (and don't have to worry about extra power adaptors for anything).· It's all powered by the laptop.
Only trouble is that the display (eMagin Z800) is really only 800x600.· However, it somehow shows most of the 1024x768 VGA display with some of the left and bottom cut off a bit.
Anybody seen a 800x600 60 Hz example?· I found a 75 Hz example, but the visor didn't like it...
Also, I'm thinking that I could run two instances of "vga" object at 800x600 and get them to take turns with the VGA port.· I think this would be the equivalent of page flipping.· Then, I could have a real 3D video display from the Propeller...·
Ray
Ray
The two images I see are different.
So just map real memory to the elements actually visible, and display nothing elsewhere.
Ah, so. I was wondering what those images were! So, what the photo shows is only a portion of what the wearer would view. And not necessarily the same area as the wearer's eyes would see.
Are they comfortable after long use; like hours? Both to the eyes and ears/nose?
Harley Shanko
h.a.s. designn
Inquiring minds want to know.
They are very comfortable.· However, in 3D mode your brain gets tired after a while...
I don't remember exactly what I paid...· Think it was $800, maybe less.· But, it looks like they want $1200 for them now...
Note that with a PC, you only get into 3D mode with NVidia graphics cards...
Ray
Graham
