can i measure car rpm with cigarette lighter — Parallax Forums
jaspittmanjaspittman Posts: 22
edited 2007-07-19 15:30 in BASIC Stamp
can i measure a car's rpm with the cigarette lighter. i know it can be done with the gtech http://gtechpro.com/index.html g-meter, and the rpm 8000 pro http://www.caesardatasystems.com/RPM8000PRO-Datasheet.pdf. but how can i bo it with a basic stamp. the 8000 pro says it measures the frequency of the ripples (100-120 per rev.) can this be measured with pulsin or is there additional hardware needed. thanks.
  • JonathanJonathan Posts: 1,023
    edited 2007-07-19 14:08
    I'm just guessing here, but...
    The signals will be WAY to small to be read by the Stamp directly. You need a minimum of I forget exactly, but lilke 1.7V, to be read by a Stamp.
    You will need to investgate op-amps and amplify the signals. I would expect a circuit like that to be a little tricky to get to work reliably.
    Much easier would be to add a sensor into the mix.
    Jonathan
    www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
    edited 2007-07-19 14:45
    jaspittman,
    Check out this thread...
    http://forums.parallax.com/showthread.php?p=566251
    Beau Schwabe
    IC Layout Engineer
  • jaspittmanjaspittman Posts: 22
    thanks beau!
