Stock#: 29121 Category: Accessories-LCD and the Boe-bot
I was wondering, is the #29121 lcd display· a replacement for LED Display Terminal AppMod #29112 for the Boe-Bot?
·· I understand that this will show you what the Boe-Bot is doing, without using· Debug terminal on your computer, is that correct?
Thanks .
Thanks .
I don't know about the particular #'s you are talking about, but take a look at this - http://www.parallax.com/dl/docs/prod/audiovis/SICSerialLcd.pdf·I think it might answer some of your other questions and get you started.
Been wanting to get one of these myself! The old "leaded" model
Stock#:·27977VC··· Category:·Accessories-LCD
<!-- Product name -->Parallax 2x16 Serial LCD (Backlit) - Leaded
DESCRIPTION:
The Parallax Serial LCD (backlit) provides a very functional, low-cost LCD that can be easily controlled by a BASIC Stamp.
Price:· $29.95
Sale Price: $25.46
Savings: $4.49
is on sale at this link - http://www.parallax.com/search_results.asp?PAGE=3&txtsearchParamCat=ALL&txtsearchParamMan=ALL&txtsearchParamVen=ALL&txtSale=1 but it seems like a I read that the backlit (of course) uses a more power than the non-backlit - if that is an issue for you.
Good luck!
Whit+
Post Edited (Whit) : 7/18/2007 12:50:15 PM GMT
The Parallax parallel lcd I provided a link for, has·one drawback with its wire connector, I sure you could cut it off and make a sutible one for the breadboard.
You might want to check out this tread too.
http://forums.parallax.com/showthread.php?p=663522
Whit+
