PWMPAL mounting
Could the PWMPAL be mounted alongside a BASIC Stamp, SX, or Propeller and just be connected to pin 0, Ground and Vdd.
Basically,
1) Is it compatible·with Parallax's other microcontrollers?
2)The necessary·connections are PIN 0, Vss and, Vdd(5V), right?
D Faust
Basically,
D Faust
You should be able to use the PWMPAL with the SX as is. With a Propeller, you'll need some kind of level conversion for the serial line since it's a bidirectional serial line. A 1K series resistor should work, but sometimes there's other circuitry (on the PWMPAL in this case) that might interfere. With the Propeller's multiprocessing, the functions of a PWMPAL are easily replaced by the Propeller itself. There are several servo drivers in the Propeller Object Exchange that can do this.
They would need to be run off the same power supply unless their Vss pins were connected, right?
Thanks for your help, it seemed like it would work, but I wanted to get another opinion.
D Faust
have a look to the diag here : http://forums.parallax.com/forums/attach.aspx?a=4150
hope this helps
D Faust
