Devantech Thermal Array Sensor
Hi all,
Check out the use of the Devantech Thermal Array Sensor (TPA81) in the article "The Follow Me Rover" by Steve Norris in Robot Mag issue 7
A schematic and BS2p code can be found at this site if you want to try out the TPA81: http://www.robot-electronics.co.uk/htm/tpa81bs2p.htm
The TPA81 is a little pricey as Jameco sells it for $130, but it can be had for as little as $103 elsewhere.
It works as advertised and I have it reporting the Ambient temp and the array pixel temps as I write this.
Have fun.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Have fun.
TCIII
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Chris
I'm not scared of your robot. I'm covered by Old Glory (youtube)
