Devantech Thermal Array Sensor — Parallax Forums
Tom CTom C Posts: 461
edited 2007-07-13 15:40 in Robotics
Hi all,
Check out the use of the Devantech Thermal Array Sensor (TPA81) in the article "The Follow Me Rover" by Steve Norris in Robot Mag issue 7
A schematic and BS2p code can be found at this site if you want to try out the TPA81: http://www.robot-electronics.co.uk/htm/tpa81bs2p.htm
The TPA81 is a little pricey as Jameco sells it for $130, but it can be had for as little as $103 elsewhere.
It works as advertised and I have it reporting the Ambient temp and the array pixel temps as I write this.
Have fun.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
  • DgswanerDgswaner Posts: 795
    edited 2007-07-13 04:02
    Nice work Tom! you saved me tons of time, that's the next sensor I'm adding to my bot. The price is a little steep for the sensor but I think it's worth it for what it will add.
    A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
  • CCraigCCraig Posts: 163
    That is a nice sensor. I just wonder how well it can see warm bodies. I saw that it can see a candle at two meters. I would think it should be able to see a candle further than that. That might be for the size of the candle and a warm body might be a bigger target.
    Chris
    I'm not scared of your robot. I'm covered by Old Glory (youtube)
