Gps Bs2
I bought a gps that Parallax offers but can not make it to work, I can see a red light blinking when I go to power it up, it should stop blinking and stay on to confirm that it is connected to a satilite. It continuously blinks, what am I doing wrong or not doing? Thank-You Toby
Chris Savage
Parallax Tech Support
I can not get any information it just blinks
I was outside for an hour and nothing
Chris Savage
The Parallax GPS should not be directly attached to the BOE breadboard!
Attach the GPS to P15 (as stated in the BS2 GPS code) via the BOE servo connector and make sure that it is at least a foot away from the BOE.
I had good results indoors (3 to 4 satellites) with the GPS on a window sill with a clear view of the sky.
Hope this helps.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
