sumobot question
hi i have gotten my sumobot full running...the only problem is the it senses the gray as out.......and also i have white creases on my mat.....it also thinks it is out...how do i fix this prblem? i know it is the qti sensors...everthing works fine though
I, too, have the SumoBots, and the manual states that you can use black marker on the white creases of the mat so that you do not have that problem.
Good Luck!
- Stephen
Stephanie Lindsay
Editor, Parallx Inc.
