How accurate is the Parallax GPS module?
How accurate is the Parallax GPS module in feet I can not seem to find it in the data sheet.
My computer, http://forums.parallax.com/showthread.php?p=630466
http://www.parallax.com/dl/docs/prod/acc/GPSManualV1.1.pdf
you will see the accuracy listed as +/- 5 meters on the average.
However, this can vary quite a bit, depending on whether or not
you are indoors or what might be blocking the signals from the
GPS satellites in reaching your antenna.
phil
Paul Baker
Chris Savage
Parallax Tech Support
This has been a Cliff Claven moment!
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
http://electronics.howstuffworks.com/gps.htm
Chris Savage
