Water soluble paste flux
Newzed
Does anyone know where I can buy water soluble paste flux?
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
- Stephen
www.smtsolderpaste.com/water_soluble_solder_paste.php
for starters. I used a Google search on "water soluble paste" and this was practically the first hit on the first page. Try it yourself.
Hope that helped.
kenjj
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Looks like it's intended for plumbing and such so the solder may be acid core, but the flux might work for what you want.
edit: actually, this may be okay for electronic stuff, they have a different kit specifically for plumbing, and I also found they sell this:
- Rick
Post Edited (RDL2004) : 6/23/2007 12:07:18 PM GMT
Kester ONLY makes solder/flux/paste for electronics.
I'd stay away from anything supplied in a jar because it typically for plumbers and contains acid which will destroy electronics.
Post Edited (Forrest) : 6/23/2007 12:27:56 PM GMT
- Stephen
Take a look at zephyrtronics no-clean RMA rework flux
Tracy Allen
www.emesystems.com
Sid
Don't have VGA?
Newzed@aol.com
Tracy Allen
www.emesystems.com
Sid
Don't have VGA?
Newzed@aol.com
I like the pens, just pop off the cap and press the tip to dispense the flux (just like those paint markers). And one pens lasts an amazingly long time.
Digikey has both the 186 and the 951 pens ($4.38 each).
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
Sid
Don't have VGA?
Newzed@aol.com
A case in point is the crystal on the DS1302. That part of the circuit board should be left very clean. The flux itself is non-corrosive and non-conductive, and much of it will burn off during soldering. However, any sticky residue might attract dust and that could later in time cause problems by loading down the oscillation circuit. But most circuits are not that sensitive.
Use it sparingly and there should be very little residue. If you use a lot of flux, for example, to help with drag soldering the pins of a fine pitch IC, it may end up with a lot of sticky mess left, unless you use some flux remover on it.
Tracy Allen
www.emesystems.com
Sid
Don't have VGA?
Newzed@aol.com
