Accidentally applied 12 volts to propeller demo board input — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2007-06-30 03:26 in Propeller 1
Hi,
·Accidentally applied 12 volts to propeller demo board input , sent it to parallax to perform a autopsy. ·They should receive it today, Can’t wait to here the results.····
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website ( Bet you can't guess why)
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2007-06-22 12:56
    When you say input I assume you mean one of the propeller's inputs? The power input will stand 12v fine.
    Graham
  • Brian_BBrian_B Posts: 844
    edited 2007-06-22 13:00
    yes one of the propellers inputs , I think it fried a volatage regulator . It don't seem like it's getting any power now.
    Thank's Brian
    www.truckwiz.com
  • deSilvadeSilva Posts: 2,967
    edited 2007-06-22 18:48
    What exactly is this thread good for?
    edited 2007-06-22 23:34
    deSilva said...
    well heres a thought, I'll tell you I messed up. I don't think that I hurt the propeller . I would like to hear from parallax what failed first , the chip or supporting circiuts . Is there somthing wrong with that?
    Thank's Brian
    www.truckwiz.com
    Post Edited (Brian Beckius) : 6/23/2007 12:18:26 AM GMT
    edited 2007-06-28 12:04
    Just I case anybody was wondering,parallax tested this board and found the 5 volt regulator to be fried.
    Thank's Brian
    www.truckwiz.com
  • rokickirokicki Posts: 1,000
    edited 2007-06-28 17:51
    Just the 5V regulator? So if they replace that, the board still will work? If true, that's amazing.
    edited 2007-06-28 20:09
    not if you applied 12v to the 5v supply perhaps.
    Graham
    Hi,
    I applied 12 volts to a input of the propeller,not·to the voltage regulator.·by mistake.
    p.s they won't fix the board,they said they would discont a new board.
    Thank's Brian
    www.truckwiz.com
    Post Edited (Brian Beckius) : 6/30/2007 3:32:34 AM GMT
