Attaching Laser Reader to a Basic Stamp...
Joe
Hi,
I would like to read line codes using a Laser Reader
and compare it with the line code stored at the Basic Stamp.
Do you know where can I find a Laser Reader
Basic Stamp compatible ( serial interface) ?
Thanks, Joe
Attached you can see a Laser Reader and a line code.
Thanks, Joe
If you are looking for something inexpensive and hobby-ish, try to find a used Cue-Cat device. I understand these can be modified to read certain types of barcodes.
- Sparks
Chris Savage
Parallax Tech Support
I have used the BL-600 from Keyence and they are nice and small I have also used the Accusort scanners and they are the best as far as industrial I know of. Symbol make some handheld units that have an interface that will output serial data also.
Curious as to the need for a barcode scanner? Is your barcode Code 39 or 128? I have font packages that you can print your own labels in excel and word if you need it.
Also for you to know Keyence will send you a demo scanner setup if you are intereseted it their products and they also have lots of sensors that are nice products.
If you need a contact number I have one.
You can always search Ebay because if we need parts we get ours from their on the obsolete models.
Post Edited (bennettdan) : 6/21/2007 10:55:02 PM GMT
I don't have experience attaching other devices.
Usually I attach Parallax products to my Basic Stamp becuase
I am sure they will work.
But my problem is that there is a lot of devices using
serial comunication and I am afraid that they couldn't
work with my B.Stamp.
Could you tell me a one or two ways ( or specifications)
that I must have on my mind before attach a serial device to my B.Stamp?
Or, using other words , do you know if all serial devices with RS232 will work with B.Stamps ?
( sorry , perhaps I am asking to much, but a little
description or a PDF recomendation to learn about that will be very usefull)
for example I found a Laser Reader that has RS232 but
I would like to know if can I use it :
http://www.metrologic.com/corporate/products/pos/MS3580.htm
My idea is that I don't like to ask you each time I find a serial device
in order to know if it is B.Stamp compatible because I don't like to
waste your time.
Thanks, Joe
I looked at ebay today and they had all kinds of handheld scanners for less than 50 dollars.
I have a freind named Chirs that works as a salesman for Keyence and like I said they can send you a demo to try out and will only cost you the shipping back to them when you are done.
