PE Kit Servo Control
This application of the Counter Modules and Circuit Applications PE Kit lab can be used to precisely control up to 14 servos in a separate cog.· All objects are written in spin.· Example programs are included that demonstrate control of two continuous rotation servos for a differential drive robot and fourteen standard servos, for a more complex robot.
Download:·PE Kit Servo Control v1.4.zip
See also:·· Propeller Education Kit Labs,·Propeller Education Kit
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 8/24/2010 6:33:53 PM GMT
Andy Lindsay
Andy Lindsay
Below -200 or above +200 the servos seem to have the same (maximum) speed.
Is this 'normal' or am I doing something wrong? The servos object allows speeds from -1000 (.5 ms pulselength) to +1000 (2.5 ms pulse length).
I·am using a propstick USB with the propeller education kit on top of a BOE bot chassis (and using the BOE bot servos).
I don't have any other power consumers on the board and I am driving the servos from the 5V power supplied by the regulator on board, while the controls are connected directly to the propstick output pins.
The whole thing is powered by 4 AA batteries...
Attached a picture of my setup ...
Post Edited (Keezinator) : 8/26/2008 6:33:49 PM GMT
