Fried my new 4x20 LCD
I plugged my LCD into the Vin, not paying attention. Now all I get are black bars no self test just the bars. Is it possible to repair it. Or cheaper to chuck it.
spydergramps
spydergramps
-Martin
thanks Martin
Join the club, all of us have fried something at least once. [noparse]:)[/noparse]
Just the other day I toasted a USB port in my PC (they don't seem to like when you short the +5V and Ground).
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
I· just· fried A RFID Card Reader About 3 weeks ago because when I went from
A Demo Mode to the powering with it owen power supply i forgot to put a
5 volt reg on the Card Reader Board It dose not work any more
So.....·Sa.aaaaa.d.ddddd· (sad)..............
Will need to·buy another one·O well
Bean
If you're not toasting stuff, you're not trying hard enough [noparse];)[/noparse]
This is so true.................
··Thanks for any·
Sam
Sorry about that.
spydergames-yea, the lcd is toast
Equipped with his 5 senses, man explores the world around and calls his adventure science
-Edwin Hubble
Twice in the last few months I've flattened my fingerprints "testing" voltage regulators to see if they were hot (they were).
I've posted this before, but I keep a copy pinned over my bench and try to read it before starting any new project, then again every hour of so as I progress. Not all the points always apply, but it reminds me to work carefully none-the-less.
Read it from the bottom up - Letterman style
Top 10 things to remember while assembling your robot:
1. Buy scrap. 85% of the time it saves a step
2. AI will have reached the epitimy of usefulness when a robot can deal with the legs of a 5-caster office chair
3. The suitability of any part for a particular purpose can be determined by count-- if you have one less than you need, its the right part.
4. Band-aids make it hard to hold tweezers
5. Resistor color bands are heat sensitive and change color while being soldered.
6. Just because the light isn't on doesn't mean the soldering iron isn't hot.
7. BASIC isn't, squares aren't, screwdrivers don't, and sensors hardly ever will. The only component aptly named is the resistor.
8. Multimeter is a fancy name for a random number generator.
9. C is for people aren't frustrated by golf and find chess stupidly simple.
10. It's not too late to become a TV sports fan.
My name is Thanos,i'm from Greece-so pls excuse any mistakes with the language- and i am a student of Biomedical Engineering.
About that lcd though...I believe you are reffering to an lcd tv? Although i've only had xp with the old tv-ies so i can't tell you about the safety rules, but if i were you i'd open it!You can never know what you might find that can b fixed!Although the situation does sound bad enough i wouldnt be convinced until i saw it with my own eyes.
Even if it is toast you may still take stuff out of it that u could use!But that is what i'd do and of course with great care!
Good luck with that LCD[noparse]:)[/noparse]
Raf
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
