Nokia LCD KnockOff and SparkFun Break Out Board Questions
I have seen and read a couple of posts on this topic, but have not seen anything more about it. Has anyone had success with it? I can't seem to get it to work at all with the demo board. There is nothing in the object exchange, so I could assume that no one has got it to work well enough to post up an object.
Any help would be appreciated.
Rob.
Rob.
- Stephen
I then connected 3.3v, gnd ·to the Sparkfun breakout board per their instructions and got the lcd to light up solid blue.
I then looked at a NokiaTest spin file and saw that it uses a spin object called Nokia LCD. Inside the Nokia LCD object I saw this line of code in the con section:
#6, CS, SClock, SData, Reset········ 'Pin assignments
So I assumed that CS was on pin 6, sClock was on pin 7, sData was on pin 8, and reset was on pin· 9. I connected the pins to the break out board, hit f10 and nothing happened.
Based on reading the code, I was supposed to see "hello" several times on the lcd screen.
Since I have very basic knowledge about electronics, I am not sure if I am supposed to do anything other than just connect the breakout board to the prop education board directly. Any help on this would be appreciated.
Rob.
I have this breakout board and had a little trouble at first, but now it works fine for me.
I might be able to help.
Is the LCD seated really well and snug in the little connector?
Did you adjust the contrast?
Try a repeat with a·delay in it to ramp up the contrast from 0 to 100 and see if that makes any difference.
It shoud be around 60-70.
Can you post your·circuit·and code·so we can take a look?
thx
fish
Did I make a unit test for it? No... Did·I run the test·suite·before checking it in? No... But it shouldn't break anything.· ~intern·(just before we let him go).
Post Edited (fish) : 6/11/2007 2:59:57 PM GMT
Do you code that you know works that I can use for the test? I will get a circuit diagram together....
thanks..
There is a thread about this called 'Nokia LCD interface anyone'·that has Paul Baker's NokiaLCD.spin Epson driver.
(Spark Fun's Nokia knock off LCD·has·an Epson controller) http://forums.parallax.com/showthread.php?p=642952
And another thread·called 'Nokia LCD Progress' that has a faster·Epson driver for called
Nokia LCD - SPI (sorta) works!.zip·where user jkroylance·got the SPI engine integration to work properly.
http://forums.parallax.com/showthread.php?p=644512
Give that a try.
You are at least getting a blue screen·on that LCD, so it sound like you are very close to getting it working.·
fish
I finally took mine off the BS2P (which never worked) and tried it on a prop proto and it's working now. The above is very basic, so if there is more developed code, I would appreciate a copy.
Paul
It's an SPI interface - nice little display! Perhaps someone has done more work on it and will chime in today.
