I assumed the setcolor pointer - 7 - would point to Line 7 of the DAT/palette and that it would change only the color of the second line of text.· Instead, it changed the whole display to brown on yellow, which is not even shown in the palette list.· What am I doing wrong?
Sid
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Yesterday is history, tomorrow is a mystery, and today is a gift.
Paul, I presume you are referring to the comments under tv_colors.· I read that section several times and I still don't understand tghe derivation of $0C.· It's not important - I am just curious.· Like I say, I really don't have to know how things work - just how to use them.
Sid
No the function "out" starting on line 114, the comment section is this:
'' Output a character
''''$00 = clear screen
''$01 = home
''$08 = backspace
''$09 = tab (8 spaces per)
''$0A = set X position (X follows)
''$0B = set Y position (Y follows)
''$0C = set color (color follows)
''$0D = return'' others = printable characters
Paul, I think there is an error in broadcast_test.· I could not get SetXY to work, and when I tried to enter text, I always had to hit the first key of a line twice.· After about four hours of trying everything and restudying the program I made the following changes to the SetXY method:
PUB SetXY(x, y) · ' This needs to be moved to the TV_Text wrapper, placed here·for·········· compatability for existing object · term.out($B)····················· ' set X position (X follows) · term.out(x) ·· ·term.out($A)······ 'was $B······· ' set Y position (Y follows) · term.out(y)
Now everything works perfectly.
Sid
Tom, I have modified the broadcast_test TV program so that you can set different colors for the text lines in the program, enter text from a keyboard, and change the color of the text you are entering "on-the-fly".
I'll post a copy if you are interested.
Sid
Tom, here is my program and the two objects I am using.· I modified some of the colors in TV_text_Paul so that is why the Rev.A.· You may have to change the keyboard pins - Lines 8 and 74 - and the TV start - Line 5.
A couple of notes - press Enter to start a new line of text.· The SetXY command is automatically incremented so you don't have to worry about that.· To change the color of a line of text you are entering, press the
" + " key by the number pad, then press the number of the color you want.· The numbers of the colors are listed at the start of the program.· Be sure you are at the start of a new line before you press +, otherwise it will overwrite the previous line.
Let me know what you think.
Sid
I have been playing around with the colors in tv_text_Paul.· Here is a picture of what I have now.· The TV screen does not photograph very well - the colors are much better than the photo but it will give you an idea.
Sid
Paul Baker
Pub Main
· repeat
··· SetXY(0,0)···· 'column, row
··· term.str(string("······ Propeller Broadcast", CR))
··· setxy(0,1)
··· term.setcolors(7)··
··· term.str(string("· Enter your text:",13,13))
··· repeat until (c := kb.getkey) == "*"
····· term.out(c)
··· start···
Sid
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
term.out($0C)
term.out(7)
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
'' Output a character '' '' $00 = clear screen '' $01 = home '' $08 = backspace '' $09 = tab (8 spaces per) '' $0A = set X position (X follows) '' $0B = set Y position (Y follows) '' $0C = set color (color follows) '' $0D = return '' others = printable characters
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
PUB SetXY(x, y)
· term.out(x)
· term.out($A)······ 'was $B······· ' set Y position (Y follows)
· term.out(y)
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Tom
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
