Fun Weekend Project - Replace the keypad entry switch on your Garage door with — Parallax Forums
Beau SchwabeBeau Schwabe Posts: 6,573
edited 2010-03-03 21:56 in Robotics
After giving up on trying to re-program the previous keypad entry access without an instruction book left by our previous home owners. (<- Problems retaining a code)
Here's something I put together over the weekend that adds yet another cool "gadget" to our household.· Enjoy!!!!
Note: Don't forget a reverse biased diode across the relay coil...
······· I used a "MAGNECRAFT W172DIP-21" which has a diode built-in ... http://www.mouser.com/catalog/630/1436.pdf··
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/11/2007 3:15:43 AM GMT
    edited 2007-06-10 21:49
    Use this program to read the TAG ID's...
    Beau Schwabe
    IC Layout Engineer
    edited 2007-06-13 01:48
    Beau Schwabe
    I· like the way you mounted the Card Reader in your door frame .............smile.gif
    How hard was that to do
    What BELLs and Whistles do you have in mind for this project................ idea.gif
    Are you going to put the Basic Stamp Board in a Project Box ..................idea.gif
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    edited 2007-06-13 04:03
    Sam,
    The Card Reader "plate" is a blank wall outlet cover I picked up at the hardware store... The offset hole actually goes through the center opening of the reader's coil. The plate is opaque enough that at night you can see the Red/Green LED through it.
    The access hole from the plate to inside the garage was already present because of a keypad that was previously there. If I were to do it from scratch, I would use a 1/4 inch to 1/2 inch masonry/wood bit (8 to 10 inches long should be enough) and just drill at an angle until I am inside.
    BELLs and Whistles?... Probably nothing more
    A project box? ... No to that as well ... since it's in the garage, what you see is what you get.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-06-13 14:11
    You could hook up a speech processor and have it announce the persons name according to the RFID tag. " Welcome home, Beau!"
    Or, maybe thats just really geeky! [noparse]:)[/noparse]
    Shawn Lowe
    My last words shall be - "NOT YET!!!"
  • Brian RileyBrian Riley Posts: 626
    edited 2009-06-05 03:42
    Beau Schwabe (Parallax) said...
    I found you can 'buy back' 5 bytes of precious RAM in a BS2 by saying
    SERIN RFIDLine, T2400, [noparse][[/noparse]WAIT($0A), HEX2 buf(0), HEX2 buf(1),
    HEX2 buf(2), HEX2 buf(3), HEX2 buf(4)]
    instead of
    SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
    cheers ... BBR
    cheers ... brian riley, n1bq, underhill center, vermont
    See the K107 Serial LCD Controller at
    www.wulfden.org/k107/
  • logan996logan996 Posts: 281
    cool, so just let me get this straight, you can have something covering the RFID reader and it will still work right?
    "When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
    ·Thomas Jefferson
