HB-25 Motor Controller — Parallax Forums
mlkakdsnldsnvmlkakdsnldsnv Posts: 5
edited 2007-06-08 23:33 in General Discussion
I was wondering about when the Parallax product page on the HB-25 Motor Controller says that it can control 1 or 2 motors in the same direction, does that mean if you have 2 motors connected they have to be running at the same time also.
  • JonnyMacJonnyMac Posts: 9,800
    The HB-25 is designed for one motor; what you can do, however, is daisy-chain two devices on the same host I/O pin -- the documentation explains the setup and signal timing differences when using two HB-25s.
