DC Motor
I am working on a senior project and I am trying to energize a 9VDC motor (which only needs about 3VDC for what I am doing with it) and I cannot get it to work.· I have tried driving a relay to power the motor and it will not work.· Does anyone have any ideas????· Thanks
D Faust
·http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv23.pdf
Post Edited (PJ Allen) : 6/8/2007 1:47:24 AM GMT
Whit+
http://www.nteinc.com/relay_web/pdf/R74.pdf
pin 1 to + of coil/motor supply
pin 2 to collector of transistor
pin 3 to + of coil/motor supply
pin 4 to motor lead #1
emitter of transistor to - of coil/motor supply
motor lead #2 to - of coil/motor supply
Connect all supply negatives together (stamp supply, coil/motor supply)
Base of transistor through 470 to 1K ohm resistor to stamp pin
Cheers,
Tom Sisk
http://www.siskconsult.com
D Faust
I appreciate everyones input.
Thanks.
You are probably missing the back EMF protection diode in the relay coil circuit. Here is a diagram which should help:
http://www.hobbyprojects.com/the_diode/diode_protection_circuits.html
Bruce Bates
At the least, the motor supply should not be fed off the stamp internal regulator.
Cheers,
Tom Sisk
