DC Motor — Parallax Forums
DC Motor
LorraineLorraine Posts: 4
edited 2007-06-09 11:53 in BASIC Stamp
I am working on a senior project and I am trying to energize a 9VDC motor (which only needs about 3VDC for what I am doing with it) and I cannot get it to work.· I have tried driving a relay to power the motor and it will not work.· Does anyone have any ideas????· Thanks
  • D FaustD Faust Posts: 608
    edited 2007-06-08 00:44
    Will the relay actually "click" Are you trying to activate the relay directly from a stamp pin becaus that won't work. Stamp pins can't supply enough current so the pin needs to drive a transistor which drives the relay. There is a schematic on the forums somewhere, but I couldn't find it. If this is not your problem then check over your wiring to make sure that the motor is getting enough voltage and is connected to ground and a voltage. Hope I helped.
    D Faust
    edited 2007-06-08 01:42
  • WhitWhit Posts: 4,191
    edited 2007-06-08 03:02
    Man, those Nuts and Volts articles are good.
    Whit+
  • LorraineLorraine Posts: 4
    edited 2007-06-08 11:52
    Yes, I have tried using a 2N3904 transistor as a switch to control a relay.· I think I may be connecting the relay wrong.· I have a DPDT relay with 10 pins---data sheet attached.· I appreciate all your input.·
    http://www.nteinc.com/relay_web/pdf/R74.pdf
  • stamptrolstamptrol Posts: 1,731
    edited 2007-06-08 12:10
    On the relay:
    pin 1 to + of coil/motor supply
    pin 2 to collector of transistor
    pin 3 to + of coil/motor supply
    pin 4 to motor lead #1
    emitter of transistor to - of coil/motor supply
    motor lead #2 to - of coil/motor supply
    Connect all supply negatives together (stamp supply, coil/motor supply)
    Base of transistor through 470 to 1K ohm resistor to stamp pin
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
    edited 2007-06-08 19:13
    Does the relay "click"?· If mit doesn't then you aren't triggering the relay and your problem is that.· If it does I would try what stamptrol said.
    D Faust
    edited 2007-06-08 19:37
    No, the relay does not click.· I am not at home right now, but I will try hooking the relay up as stated above.· I have to hook it up so that the arm on the motor will turn clockwise and counter clockwise.· This whole project is to lock and unlock a door.·
    I appreciate everyones input.
    edited 2007-06-08 23:23
    Ok--Here is the update--the relay is working but it like shorts everything out when I plug it up to the motor. When I put an LED on the output of the relay it works. Does anyone have any ideas on what to do with this problem?
    Thanks.
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2007-06-09 06:36
    Lorraine -
    You are probably missing the back EMF protection diode in the relay coil circuit. Here is a diagram which should help:
    http://www.hobbyprojects.com/the_diode/diode_protection_circuits.html
    Bruce Bates
    Also, what are you using for a power supply? Sounds like you're drawing too much current and the voltage is collapsing.
    At the least, the motor supply should not be fed off the stamp internal regulator.
    Cheers,
    Tom Sisk
