heating up a Resistor
Dorling
I need the javelin stamp to heat up a temperature sensor (LM35). I plan to do so by using a 100R 6W Resistor. If I connect 12v and GND to the resistor it does heat up. I need this to be done by the javelin stamp. So my program at control when it is on or off! This is going to be use in a temperature control system. There is a Fan to cool the sensor down this is done by a L293D.
I plan to use a transistor or a darlington transistor or maybe a relay would be best. If any one get out me out as I don't want to blow my javelin up!
Jonathan
Post Edited (Dorling) : 6/5/2007 9:45:41 PM GMT
Jonathan
D Faust
(javelin)CPU.pin0 ----> pin1 (Opto Transistor)
GND----pin 2 (Opto Transistor)
Vss(12v) ---- RESISTOR----pin 16 (Opto Transistor)
GND----pin 17 (Opto Transistor)
so when CPU.pin0 is high it is heating the RESISTOR up and when it is off it is NOT heating it up!
Jonathan
