Scribbler Pen — Parallax Forums
Scribbler Pen
WhitWhit Posts: 4,194
edited 2007-06-04 11:59 in Robotics
I am about to led a short camp using the Scribbler. I got to thinking about using a different pen·instead of·a permanent Sharpie for the line tracing. Anyone with experience using different pens?
I can just see the Scibbler running will across the floor leaving a permanent line!
Whit+
  • DaveTheCaverDaveTheCaver Posts: 1
    edited 2007-06-04 03:39
    Prevention is better than the cure. Can't help with the prevention bit. Permanent Marker ink can normally be removed using Acetone (nail polish remover).
    edited 2007-06-04 04:10
    Try to find a "dry erase" marker that size, it just wipes off with a cloth.
    edited 2007-06-04 06:24
    If you can get to it soon enough, WD-40 will remove permanent Sharpie.... depending on the floor type (linoleum, vinyl, etc.), a "thin" version dry erase pen (mentioned above) or overhead projector pen should work.
    Beau Schwabe
    IC Layout Engineer
  • WhitWhit Posts: 4,194
    Thanks to everyone for the suggestions.
    Whit+
