servo specs — Parallax Forums
servo specs
El PaisaEl Paisa Posts: 375
edited 2007-06-01 17:18 in General Discussion
Probably this is not the right place, if not please forgive me.
There is any standarized specs for the servos specially the GWS .
Such things like Total angle rotation, angle per step?
  • simonlsimonl Posts: 866
    edited 2007-06-01 08:41
    Not as far as I know. In my experience total angle rotation and angular resolution are not only different between manufacturers, but also different between servo models. Indeed, these can also vary slightly between servos of same model!
    You'll need to look at the detailed spec's of the servo(s) you want to use I think.
    Cheers,
    Simon
    www.norfolkhelicopterclub.co.uk
    You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
    BTW: I type as I'm thinking, so please don't take any offense at my writing style smile.gif
    This thread is being moved from the Propeller Forum to the Sandbox Forum.
    Chris Savage
    Parallax Tech Support
