Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
BS2 and Smoke Detectors — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Waveman
20
2007-05-31 00:49
edited 2007-06-05 16:31
in
BASIC Stamp
Has anyone every tried to interface a smoke detector to the BASIC STAMP BS2? Either photoelectric or ion type?
WaveMan
wurx
10
2007-05-31 12:10
edited 2007-05-31 12:10
3 things come to mind.
1 - if you just want to see if it is registering an alert, you could easily get a signal from the piezo speaker.
2 - Using a basic stamp in conjunction with or instead of a smoke detector is unreliable and dangerous.
3 - Experiment, learn, explore...yes. Use in real life, ABSOLUTLY NO!
Good luck, have fun.
Chris Savage
Parallax Engineering
14,406
2007-05-31 14:29
edited 2007-05-31 14:29
This is a duplicate thread. Post replies only to the original thread at the following link.
http://forums.parallax.com/showthread.php?p=653298
Chris Savage
Parallax Tech Support
Waveman
20
2007-06-05 16:31
To Wurx,
Thanks and not using BS2 in place of a
''real"
smoke detector. Just an application that will go in a test equipment rack in an industrial environment to
detect sever equipment overheating and potential fire.
WaveMan
Sign In
Register
to comment.
Chris Savage
Thanks and not using BS2 in place of a·''real"·smoke detector. Just an application that will go in a test equipment rack in an industrial environment to·detect sever equipment overheating and potential fire.
WaveMan
